Guardtec 300 Series
russ1364
HI Folks,
I have a new neighbour ( :)very nice!) she has moved in and the house has a Gardtec 300 series fully installed. At the moment it is disconected from the mains and the back up battery.
The Question???????
What is the factory reset code then it will lose all the other codes, I have a user manual for it to set it back up fror her but no codes, It goes without saying that I dont know the old code and have no way of finding out. Can anyone help?
an Istallation manual would help, if its available!
Many Thanks
Russ
Sorry Russ we can't give out info on defaulting panels or engineering manuals. You could try to get a manual but if all fails why not get an engineer to service the system and check everything is ok. Simply switching it on is not the right way to go as the alarm has been turned of for a period of time. Has the battery got a date on it?? The outside bell battery will be dead aswell.
Good luck with the neighbour!!!
