shinfieldmonkey Posted February 28, 2008 Posted February 28, 2008 hi folks just want to gauge opinion on communicators i've always used redcare but am toying with the idea of dualcoms. What are your experiances good or bad Mark Terry A.M.I. Security Covering the Thames Valley Tel. 01189 775173 24hours mark.terry@amisecurity.co.uk
IPAlarms Posted February 28, 2008 Posted February 28, 2008 hi folksjust want to gauge opinion on communicators i've always used redcare but am toying with the idea of dualcoms. What are your experiances good or bad The Australian equivilent of Redcare is being phased out down under (no more new connections and plug pulled next year) and I don't think it will be much longer before you hear a similar announcement from BT. IMHO - Dual path IP/GPRS is the way to go Free Alarm Monitoring over the Internet from IP Alarms
Barsnake Posted February 28, 2008 Posted February 28, 2008 The age old question EDITTED Answer as Public SORRY
Guest anguscanplay Posted February 28, 2008 Posted February 28, 2008 The Australian equivilent of Redcare is being phased out down under (no more new connections and plug pulled next year) and I don't think it will be much longer before you hear a similar announcement from BT.IMHO - Dual path IP/GPRS is the way to go you seen the draft insurance requirments for IP yet ?
IPAlarms Posted February 29, 2008 Posted February 29, 2008 you seen the draft insurance requirments for IP yet ? No I haven't - are you going to point me in the right direction ? Free Alarm Monitoring over the Internet from IP Alarms
IPAlarms Posted February 29, 2008 Posted February 29, 2008 If your looking for an alternative for RedCARE, try looking at the Emizon product. ...and don't forget Webwayone, Chiron, Terrier or IP Alarms Then you need to look at moving ARC's because none of them are likely to offer all solutions. Many will offer only one. Free Alarm Monitoring over the Internet from IP Alarms
billythebellbox Posted February 29, 2008 Posted February 29, 2008 I don't think it will be much longer before you hear a similar announcement from BT. Redcare been going 20 yrs? chances are it will still be going 20 more? De Do Do Do, De Da Da Da. De Do Do Do, De Da Da Da
Guest anguscanplay Posted February 29, 2008 Posted February 29, 2008 Redcare been going 20 yrs? chances are it will still be going 20 more? what dates 21CN start?
billythebellbox Posted March 1, 2008 Posted March 1, 2008 underway Will Redcare alarm signalling services be compatible with the 21CN? BT Redcare’s alarm signalling network has been tested under both laboratory conditions and under simulated live conditions. All redcare network testing conducted to date has proved to be 100% successful and shows that redcare products will work normally on the network once it has been switched-on. BT expects the vast majority of customer premises equipment (CPE) connected to current telephone lines and broadband services will work normally on the network once it has been switched-on. De Do Do Do, De Da Da Da. De Do Do Do, De Da Da Da
