Anpr
camerabloke
got some ANPR quoting to do and wondered what you guys would recommend?
cameras and software
Appian, and it's NAAS compliant.
Ilkie
Derwent Cameras are whats use on the motorways. I've used 1 on an entrance to an site, linked to a single channel dvr, and no matter what speed my fellow engineer went past, it always gave an excellent image of the no. plate.
Not cheap though...
Not cheap though...
Used one of those myself connected soly to a DVR. What software would you use with these in other applications and how would you connect up?
PIPS 362's feeding a Citysync engine, or PIPS 372 standalone. I've got this config all over the UK on various motorways & 'A' roads and is NAAS friendly with regular 98-99% overall.
What's the application, Camerabloke?
I went up into the attic...I found a Stradavarius & a Picasso. Unfortunately.....
Stradavarius couldn't paint, and Picasso made a shocking fiddle.
My Facebook page...http://www.facebook.com/home.php#/profile.php?id=1279556853&ref=name
Have been investigating this for the last 3 mnths with various companies offering evaluations on site and the only one which so far gives an all round good quality performance with up to two additional overview capture pictures and within the budget required has been the "appian" the problem with citysinq is that they charge huge software support charges to the bussiness partners for individual sites which have to be passed on to the customer but with appian the software is a one off charge and the support is on going .
I am in the process of final quotes for the project i am investigating using appian gear.
Hope this helps regards Paul.
Thanks for the replie.
No application as yet, just that i want to get my head around what you guys use so i can branch out into this field
Eucam Security Systems
0845 4630 746
www.eucam.co.uk
ive used a smsung 415 with extenal ir lamp with a standalone single channel dvr recordong real time 1000 gb, with very good resuts from it.
cheers
07475071344
Can I ask a a slight off topic question? Is ANPR software able to recognize non standard number plates? ie Metro font etc
The software can be used to read justabout anything if the supplier will write the appropriate mods, sugest you contact Appian and ask if they would be prepared to do it Paul
