jgray Posted March 2, 2008 Posted March 2, 2008 Hi guys First post and surprise surprise I have a problem. I have an Optima XL6 alarm which has been upset due to new flooring being put down. The wire which I assume leads to the external alarm has been cut (8 core)accidentaly. On the wire being cut the alarm was triggered, having had no response from inputting my code we phoned the engineers who informed us to turn off the mains. open the panel and remove the battery, remove the fuse and turn the mains back on. informing us that the outside alarm would stay on for between 15 minutes and two hours, it has now been five hours. The enginners told us to phone tomorrow regarding repaiting the system. is ther any way of turning off the outside alarm, is it on a battery? Any help would be appreciated, before I get lynched by the neighbours. Many thanks
satsuma01 Posted March 2, 2008 Posted March 2, 2008 Hi guys First post and surprise surprise I have a problem. I have an Optima XL6 alarm which has been upset due to new flooring being put down. The wire which I assume leads to the external alarm has been cut (8 core)accidentaly. On the wire being cut the alarm was triggered, having had no response from inputting my code we phoned the engineers who informed us to turn off the mains. open the panel and remove the battery, remove the fuse and turn the mains back on. informing us that the outside alarm would stay on for between 15 minutes and two hours, it has now been five hours. The enginners told us to phone tomorrow regarding repaiting the system. is ther any way of turning off the outside alarm, is it on a battery? Any help would be appreciated, before I get lynched by the neighbours. Many thanks the bell box will have a back up battery which if you know where it is can bee disconnected, but i cannot due to the rules of the site say how to deactivate this siren, in the public forums is the bell box siren still sounding now, if it is the reason sounds like you have blown the siren fuse when the cable was chopped and therefore the supply current is not travelling to the bell box, could you not join the cable back together, using colour to colour method, and replace the blown fuse in the panel, with one of the same rating then repower the mains back up **WARNING opening the panel exposes 240volts and can/will kill if itelectrocutes you, disconnect the 240volts main supply before proceeding with openeing the panel. the battery should hold the programming for the short time you change the blown fuse. the sytem should sound when the system panel cover is opned simply putting your code in should silence it and pressing reset or equivelant should then once the panel is back together reset the system ready for operation until you can get a engineer out tommorrow hope this makes sense to you kind regards colin "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
jgray Posted March 2, 2008 Author Posted March 2, 2008 the bell box will have a back up battery which if you know where it is can bee disconnected, but i cannot due to the rules of the site say how to deactivate this siren, in the public forumsis the bell box siren still sounding now, if it is the reason sounds like you have blown the siren fuse when the cable was chopped and therefore the supply current is not travelling to the bell box, could you not join the cable back together, using colour to colour method, and replace the blown fuse in the panel, with one of the same rating then repower the mains back up **WARNING opening the panel exposes 240volts and can/will kill if itelectrocutes you, disconnect the 240volts main supply before proceeding with openeing the panel. the battery should hold the programming for the short time you change the blown fuse. the sytem should sound when the system panel cover is opned simply putting your code in should silence it and pressing reset or equivelant should then once the panel is back together reset the system ready for operation until you can get a engineer out tommorrow hope this makes sense to you kind regards colin Thanks Colin The ringinig is just a contiuous tone. I have tried rejoining the wires together colour to colour using a connecting box. I have not reconnected the battery or the main fuse as the engineer said nothing about replacing and so have left everything as was. I assume the potential blown fuse would be the fuse within the panel. Is the external siren running on battery power? Many thanks for your help
jgray Posted March 2, 2008 Author Posted March 2, 2008 Thanks ColinThe ringinig is just a contiuous tone. I have tried rejoining the wires together colour to colour using a connecting box. I have not reconnected the battery or the main fuse as the engineer said nothing about replacing and so have left everything as was. I assume the potential blown fuse would be the fuse within the panel. Is the external siren running on battery power? Many thanks for your help Just checked the panel and yes the fuse has blown, where is the best place to find a replacement 1.6 amp fuse
camerabloke Posted March 2, 2008 Posted March 2, 2008 maplins, shuts at 4 though Eucam Security Systems 0845 4630 746 www.eucam.co.uk
jgray Posted March 2, 2008 Author Posted March 2, 2008 Thanks for your replys The thing has finally stopped so will get resolved tomorrow. Did try B&Q but they had nothing.
