Scantronic 9448+
have just replaced an old syhmpony panel with scantronic 9448+
there is no SAB external bell, but sounders intenally x 2 110db premises is an isolated youth centre so loud intenal sounders, work well if activated as intruders cant stand noise level ,its to loud to enter premises.
we want to retain this method but cant seem to get a 12 volt supply from bottom connections on bell/strobe connectors
have linked tamper pair as per installation manual
the resistance for internal sounders is above 16 ohms, so will not work off internal sounder supply
any help welcome
graham
Are they speakers or sounders?
if they are speakers they will not work on the bell connections,you need to use the LS terminals. but 16 ohms max
if they are sounders i suggest you use a power supply to feed the sounders through a relay
Hope this helps
Eucam Security Systems
0845 4630 746
www.eucam.co.uk
how are you connecting your sounders up to 9448+ ie black to ? red to ?
paul
THE BLACK KNIGHT
sounds a bodge job, glaxay + redcare & contract with proper firm are the order of the day ;)
De Do Do Do, De Da Da Da. De Do Do Do, De Da Da Da
