Superdave Posted March 4, 2008 Posted March 4, 2008 My panel is a 17 yr old Itec Meridian (UK) and I've got a new Texecom Odyssey 3E Bellbox, I've removed the old box but am a little unclear as to what wire goes where on the new one. Have 8 core running from Panel to box, only 4 are utilised from panel, they are, Ext Bell +ve Red Ext Bell -ve Yellow TR Blue, this has a resistor fitted and I think comes from Bell Tam. BHO Black, this goes to SAB, whatever that is, according to the Merdian manual Old Box Connections A = Red , linked off to Strobe B = Yellow, linked off to strobe C = Black D = Blue New box has A = 12v +ve B = Bell -ve C = Tamp D = OV S = Strobe -ve Perhaps somebody could indicate which wire I should connect to which connection on the Odyssey, I would be extremely grateful. Dave
billythebellbox Posted March 4, 2008 Posted March 4, 2008 My panel is a 17 yr old Itec Meridian (UK) and I've got a new Texecom Odyssey 3E Bellbox, I've removed the old box but am a little unclear as to what wire goes where on the new one.Have 8 core running from Panel to box, only 4 are utilised from panel, they are, Ext Bell +ve Red Ext Bell -ve Yellow TR Blue, this has a resistor fitted and I think comes from Bell Tam. BHO Black, this goes to SAB, whatever that is, according to the Merdian manual Old Box Connections A = Red , linked off to Strobe B = Yellow, linked off to strobe C = Black D = Blue New box has A = 12v +ve B = Bell -ve C = Tamp D = OV S = Strobe -ve Perhaps somebody could indicate which wire I should connect to which connection on the Odyssey, I would be extremely grateful. Dave won't work,need to bodge an eol circuit on a relay for return De Do Do Do, De Da Da Da. De Do Do Do, De Da Da Da
alterEGO Posted March 4, 2008 Posted March 4, 2008 Although upgrading the bellbox is a good idea, you need to think about upgrading the control panel and system itself. We cover your area, feel free to give us a ring if you would like a quote.
