Eurosec Cp8 Keypad Wiring
omega1
mjw,
You asked the difference between parallel and series. Well the difference is Alarm engineers wire door contacts in series and electricians wire them in parallel. No joke!
mjw,
sort of an alternative to 'double knock' :lol:
regs
alan
  • 3 weeks later...
I seem to have opened up quite a can of worms here.
After speaking to Gardtech technical it appears that the keypads can be wired directly from the keypad (parallel)
The resistor can be fitted on either keypad but the one on the longest wiring run is preferable.
Thanks to all who offered advice.
Well done to ViperMK2 for the perfect answer.
Kevin
Kevin
that will work, but the intermediate keypad on the shorter run will not have any anti-tamper protection, fine for your own install but trade fitters have minimum standards we have to adhere to :) .
in a private house if forced into a choice, i'd rather have anti-tamper on the ground floor keypad in preference to the keypad on the landing, imo simply the most likely to be attacked but usually the shorter cable run.
regs
alan
yes and no LOL - its series because it goes to one then the other, but its parallel to the first connection LOL ( if only you knew how often me and " some friends" have the same argument)
I always bring the D1 D2 back to the panel on a spare pair then take them out to the second keypad - hang over from the old days I suppose
what I`m trying to work out is doing it your way ie pure parallel - is hows the keypad without the resistor tampered? you dont give it a keypad ident like the CPX
actually old chaps its 'bus' wired.
'BUS wiring= method of connecting common data lines between computer processors', and before Angus starts the end station is mini computer so is the keypad :P so your both wrong - and so is Gardtec Technical (unusually! :no: ) :lol:
regs
alan
Guest anguscanplay
regs
alan
hindsight - makes you great, eh Arf?
i was waiting for someone else to state it - perhaps even you, but i gave up waiting in the end.
so perhaps this old over the hill unregulated reprobate knows a lot more about wiring standards and usages than you ever give me credit for :P
regs
alan
Guest anguscanplay
regs
alan
not really - we still dont know if it will see the tamper on the unresistered keypad or not
unless its been changed fairly recently in software (i've stopped using them now in favour of the cpx/G490), then no it won't on this panel, will on the cpx/490 but only if you enroll the extra keypad/s number/s
regs
alan
Guest anguscanplay
regs
alan
which is what was said by someone way way back in post 6 if you care to scroll back, so the answer to the question is no you cannot wire them star configeration (they may work BUT not correctly) its not a true data "bus " and thats why you dont get crosstalk if you run them up and back down the same cable (which I would never do on a proper data bus as I also said ages ago)
regards
