Texecom Dialler on a Scantronic 9600
Guest Steve H
Guest Steve H
What the best way to trigger the dialler, there is no relay card or outputs available.
If there are no outputs i would wire the intruder trigger to the negative bell ouput. This will trigger the dialler when the alarm sounds and if someone resets the alarm the dialler will automatically cancel.
Dave
Guest stuartbe
If there are no outputs then the best way would be to use the bell trigger. Set the dailer to use -applied inputs and connect a wire from the -bell trig output.
HTH
