Jim Posted March 8, 2008 Posted March 8, 2008 Hi Following the destruction of my previous SAB by workmen I have purchased another. The problem is the markings on the new one differ from the old. I would be most grateful if one of you experts could advise please to match the terminals up. Thanks in advance. Jim OLD SAB +V SW -V RET (two other wires to optional strobe) D B A C NEW SAB STB- TRIG HOLD OFF- HOLD OFF+ RTN- BATTERY- BATTERY+ Thanks in anticipation
arfur mo Posted March 8, 2008 Posted March 8, 2008 HiFollowing the destruction of my previous SAB by workmen I have purchased another. The problem is the markings on the new one differ from the old. I would be most grateful if one of you experts could advise please to match the terminals up. Thanks in advance. Jim OLD SAB +V SW -V RET (two other wires to optional strobe) D B A C NEW SAB STB- TRIG HOLD OFF- HOLD OFF+ RTN- BATTERY- BATTERY+ Thanks in anticipation Old - New +V = Hold Off + SW = TRIG (makes siren sound) -V = HOLD OFF- RET = RTN (which is anti tamper return) you only need the negative drive for the strobe, taken from the remaining 'pair' of cables, the other cable wil be a 'standing' positive so insulate properly to prevent shorts. the battery may be connected to trminals or need to be so, check your instruction as model very. please be aware, sudden unexpected operation of the siren may startle you, which then may cause you to fall, also do this work at a reasonable time of day out of consideration for you immediate neighbours regs alan If you think education is difficult, try being stupid!!!!
Jim Posted March 8, 2008 Author Posted March 8, 2008 Old - New+V = Hold Off + SW = TRIG (makes siren sound) -V = HOLD OFF- RET = RTN (which is anti tamper return) you only need the negative drive for the strobe, taken from the remaining 'pair' of cables, the other cable wil be a 'standing' positive so insulate properly to prevent shorts. the battery may be connected to trminals or need to be so, check your instruction as model very. please be aware, sudden unexpected operation of the siren may startle you, which then may cause you to fall, also do this work at a reasonable time of day out of consideration for you immediate neighbours regs alan Alan...you are an absolute gentleman, Sir Thanks so much
arfur mo Posted March 9, 2008 Posted March 9, 2008 Alan...you are an absolute gentleman, SirThanks so much SHHHH! just keep it to yourself regs alan If you think education is difficult, try being stupid!!!!
mjw Posted March 9, 2008 Posted March 9, 2008 He's been called lots of things but ??? especially by chesterfields no 1
arfur mo Posted March 9, 2008 Posted March 9, 2008 especially by chesterfields no 1 thats just what happens - when he's up against the WORLDS No.1 regs alan If you think education is difficult, try being stupid!!!!
topalarms Posted March 9, 2008 Posted March 9, 2008 especially by chesterfields no 1 Chesterfield? Some country backwater?
mjw Posted March 9, 2008 Posted March 9, 2008 Chesterfield? Some country backwater? must be mate...i dunno where it is
arfur mo Posted March 9, 2008 Posted March 9, 2008 must be mate...i dunno where it is until recently chesterfield was actually 'just a field' and the council did not think it worth naming it regs alan If you think education is difficult, try being stupid!!!!
