Where Can I Get ?
BobClarke
Hi all,
Anyone know where i can get the following at a decent cost?
Hand held cable length meter , video bar generator.(PAL)
All the ones i have seen so far cost a packet ! I'm not looking for anything flash.
Many thanks.
Hi all,
Many thanks.
kep a check ebay, search for a fluke 520 which is a CAT5 tester, i use mine with 2 blocks made from speaker connectors for quick connection.
gives cable legnth, resistance and wire map as well as distance to short or break fault.
regs
alan
NG Systems do the kit you are looking for, available from norbain, ACT meters, ADi-Gardiner etc, about
kep a check ebay, search for a fluke 520 which is a CAT5 tester, i use mine with 2 blocks made from speaker connectors for quick connection.gives cable legnth, resistance and wire map as well as distance to short or break fault.regsalan
Thanks for your reply Alan . will keep an eye out.
