Discontinued Alarm System Now With Fault
pedros143
We moved into house with scantronic 9454 system installed .. had it maintained every 12 months. Current company withdrawn support last year as system is discontinued unless we pay an extra amount over and above and will not guarantee work. They keep offering to re install a new system costing
Battery get a service engineer in to replace. Also get him to check the charging cicuit
Mark Terry
A.M.I. Security
Covering the Thames Valley
Tel. 01189 775173 24hours
mark.terry@amisecurity.co.uk
when you disconnected the fuse to the panel did the out side sounder not start to ring? If you have removed the fuse and the panel is dead! then you deffo need a new battery and poss your battery back up in the panel may be faulty too!
My Name is Iain
iStorm Security Solutions
9454 is of the around 15 years old vintage, take a car of similar age into the main dealer & see if the chaps in the garage are up to speed on 'em?
9454 is plastic on board keypad type & does not monitor for battery fault if i recall right but has been 10 years since I have had the pleasure
De Do Do Do, De Da Da Da. De Do Do Do, De Da Da Da
this guy must have been service by a well known tyre company, you know you go in for a fer tyres come out with a full set of new shocks and a steering rack.
we don't have the full details, only what you print. but based on that i would not remove service to a reliable and loyal client due to the panel becoming obsolete, i would at least offer to upgrade it to a later model but definately would not cost 1000's
get another company with a bit more customer relations on board, as i'm not alone in offering a very god service.
your in the 'south east', so post you town/area and someone who covers your local will i'm sure contact you promptly, sorry though as it might not be me as i'm absolutely 'rammed' with work, unless you near Wickford ;) .
:P
regs
alan
it's the age old I can do almost anything, however can could you find a member of staff to work with a 100 different type of controls with out "fluffing it" up?
Oh c'mon, a ..yrs old Scanny, with the paperwork, what could be easier?
If they can't cope, give them a paint brush, that might be easier.
modern gal with lcd
buggers keep standing on the roof rack ;)
modern gal with lcd
You not read the first post then?
