Discontinued Alarm System Now With Fault
pedros143
scantronic panels allways sound the internal sounders every 30 seconds if the battery is faulty, Give us a call and we can courier out a new battery for you.
cheers
lee
....Thanks for a constructive answer, i will contact you direct.
9454 is of the around 15 years old vintage, take a car of similar age into the main dealer & see if the chaps in the garage are up to speed on 'em?
9454 is plastic on board keypad type & does not monitor for battery fault if i recall right but has been 10 years since I have had the pleasure
wrong - the 9454 (and its smaller brother the 9252) had battery monitoring circuits, i would take up the kind option of a couriered battery , replace it and see how it goes. As also stated tho the external sounder should have made a noise when you removed power/panel went totally dead, so you would probably benefit from a replacement external sounder as well. I,m sure you can find a local small installer who will give you a sensible quote for this. But as long as the bell/sounder sounds when you get your system working again (ie set it, activate it on a sensor) then all will be ok in short time.
Paul
THE BLACK KNIGHT
out of the car window on your way back to branch?
OH Dear i think more like yeee haaa...did'nt know horses come fitted with windows these days :P
can you get steel toe capped cowboy boots?or a ten gallon hard hat?
Eucam Security Systems
0845 4630 746
www.eucam.co.uk
