mjordan Posted March 14, 2008 Posted March 14, 2008 HOMELINK 55 ALARM PANEL SYSTEM Hi, We have some wired PIR connectors to wire into this panel, Honeywell IS-215TQ type, and we would like confirmation on the wiring into the panel. We suspect the following: PIR Tamper x 2 = Gobal tamper on Panel x 2 PIR -12V +0V = -12V, +0V connections on panel PIR C & NC connections = how would they be wired onto the panel Also, we have a Gartec Eurosec XS3D sounder to wire, this type is not listed in the instruction book for the panel, so can anyone advise what the wiring onto the pane would be go based on the following: XS3D Sounder Connections: ST- (STROBE) TMPR (SAB TAMP) S- (BELL-) 12V (BELL+) 0V (BELL HOLD-) Many thank. HOMELINK_v_HONEYWELL_PIR_WIRING.pdf HOMELINK_55_BELL_BOX_WIRING.pdf
Monty Posted March 15, 2008 Posted March 15, 2008 as you have listed all the connections that are quite clear to any one with knowledge of alarms and you are unsure what goes where would suggest it would be safer to employ a local firm to do the work for safety reasons I know this not what you would like to hear but better in the long run . www.AllanMoncrieffAlarms.com
time served Posted March 15, 2008 Posted March 15, 2008 Nice system, have you even managed to wire up the wireless receiver as of yet, your post does suggest that you are struggling with the basic's and have not even got to the programing. I fear that Monty may be offering you sound advice.
