mjordan Posted March 14, 2008 Posted March 14, 2008 HOMELINK 55 ALARM PANEL SYSTEM Hi, We have some wired PIR connectors to wire into this panel, Honeywell IS-215TQ type, and we would like confirmation on the wiring into the panel. We suspect the following: PIR Tamper x 2 = Gobal tamper on Panel x 2 PIR -12V +0V = -12V, +0V connections on panel PIR C & NC connections = how would they be wired onto the panel Also, we have a Gartec Eurosec XS3D sounder to wire, this type is not listed in the instruction book for the panel, so can anyone advise what the wiring onto the pane would be go based on the following: XS3D Sounder Connections: ST- (STROBE) TMPR (SAB TAMP) S- (BELL-) 12V (BELL+) 0V (BELL HOLD-) Many thank. HOMELINK_55_BELL_BOX_WIRING.pdf HOMELINK_v_HONEYWELL_PIR_WIRING.pdf
djrock Posted March 14, 2008 Posted March 14, 2008 Hello, Brown and blue is your power, red and orange is your zone and green and white is your tamper. Since your tamper is a global one it will need to be wired in a series with any other devices tamper. I think this is the right way to wire the bell. I might be wrong. Op1 is bell- Op2 is strobe- Tr is sab tamp 12v aux is bell+ 0v is bell hold- djrock
mjordan Posted March 21, 2008 Author Posted March 21, 2008 THANKS FOR THE INPUT. FOR THE PIRS, THE PWR AND THE GLOBAL TAMPER ARE OK NOW, IT WAS JUST THE WAY THE ZONES ARE WIRED, WHEN U WIRE SAY ZONE 1, AND THEN MOVE ON TO ZONE 2, DO YOU JOIN ONE OF THE WIRES FROM ZONE 1 & 2 TOGETHER ?
magpye Posted March 21, 2008 Posted March 21, 2008 THANKS FOR THE INPUT.FOR THE PIRS, THE PWR AND THE GLOBAL TAMPER ARE OK NOW, IT WAS JUST THE WAY THE ZONES ARE WIRED, WHEN U WIRE SAY ZONE 1, AND THEN MOVE ON TO ZONE 2, DO YOU JOIN ONE OF THE WIRES FROM ZONE 1 & 2 TOGETHER ? Yes, as per the PIR connection drawing from your first post Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
