Eurosec Cp8 Rkp Fault
coops
I, having a problem trying to locate a fault with a eurosec cp8 lcd rkp.There is no poer going to rkp,control panel is powered but feel I might have a faulty rkp.Does anyone have any suggestion of what else I can try?
Put a multimeter on the power pair at the keypad end and see if your getting voltage. If you are you have a faulty keypad if not test the panel end as it could be a blown fuse or a faulty cable.
lee
Lee Sutton
E-Mail: leesutton@centurianfire.co.uk
Website: www.centurianfire.co.uk
Phone: 0845 094 9870
CENTURIAN FIRE & SECURITY (part of centurian group limited)
as above with a slight difference, 1st check you have 12 volts leaving the control panel from the designated RKP connections, but my guess though is you have not installed the EOL resistor as shown in the instructions and sometimes taped onto the control panel carton.
regs
alan
