Veritas 8c Blowing Fuse
don1dragon
Hello there,
I have a problem with my Veritas 8C.
Over the past couple of weeks the alarm has gone off a couple of times and was easily reset using the code.
Yesterday I found that the power light had gone out. After investigating, it turned out that the fuse in the mains terminal had blown.
I replaced the fuse and everything was ok.
Now I have just found that the control panel is completely dead, no lights at all. I suspect the fuse again, but due to it being the middle of the night, I'm too tired to investigate tonight :(
If this mains fuse has blown again, what is the most likely problem?
cheers
Steve
it means there is a fault on the panel of some description, you should call an engineer out firstly to diagnose the fault and then go from there.
Eucam Security Systems
0845 4630 746
www.eucam.co.uk
