Best External Static Camera?
justin
Hi guys.
I Have a site where I need to install alot of external cameras. Iwould normally try and keep the camera numbers down and site PTZ domes to cover most areas. In this case static's must be used externally. I have used Bosch day nights mainly in the past and Videcons newish all in one twin IR lamp type. I was wondering If anyone has used the Night devil dome from SQ?
Static domes would look alot neater on this new buiding. So does anyone use a decent external static dome thats both quallity day and night and also varifocal ?
Any help much appriciated.
Thanks Justin.
Hi guys.
Thanks Justin.
baxall ICE dome :yes: 540TVL or Dennard dome
Thanks. What is the full product code for the baxall external camera? Do Dennard do a static dome?
http://dynamic-cctv.com/PDF%20files/DTV-VLD(OSD).pdf
this is a dome from dynamic cctv uve used many times
very good vakue for money
07475071344
yes dennard do a very good static dome, but i favor those baxall ICE :yes: I've installed thosands of cameras BUT day/night can be headace.
those baxall ICE+ cameras are as sharp as a sony camcorder, and there not grainy when switched to night. the best ive ever played with in my life.
http://vcab.com/search/vcab-info.aspx?vcab...9&show=info
http://www.norbain.com/products//manufactu...l/show:current/
http://www.norbain.co.uk/support//datashee...D43EB071958126/
but if you want dennard then there is some on ebay at the moment
