Ps3 Setup
justin
Does anyone know if I will need to do any port forwarding in my router to play PS3 games online?
Do different games use different ports?
I am connecting it up tomorrow, just wonderd what I might need to do.
i have an xb360 and used to use a PS2 online, which sorted itself for themselves just as any other pc.
i don't think you will have any issues as port forwarding tend's to be for remote access to a target pc.
regs
alan
I think you'll find its 'plug and play', if anything turn on UPnP in your router.
No port forwarding required, thats usually when speeding up torrents. Installed PS3, just follow online prompts, some games need an online upgrade before the online capability kicks in.
You will only have to type in your wep key from your router.
PS3 and XBOX360 are plug and play very easy to set up only had problem setting up my Nintendo Wii on a BT Home Hub, ended up switching the router channel to 11 from 1 to stop it disconnecting on me.
