Fire Alarm Regulations ?
Hi there i am not to sure about this so i am goin to through it out and hopefully someone can give some feedback ?
My question is. Can someone who is self employed but not have any actually fire qualification but is quite capable of fitting a fir system actually fitted, commision and handover to the customer an audible onlt none signalling system ?
If any qualifications are needed what are they ?
Many Thanks . :rolleyes:
Hi Justin
Quick answer is no. But you can install if you are electrically qualified but you would need a reputable fire company to come in and certificate the system to make sure that it confirms to BS 5839
That is the short answer but someone else may add the full reasoning.
Pete
Peter Robinson
Freelance
M:07889038650
Guest G.J.M
you are required to prove your competance in the relevant areas i.e install,design etc
You can only do this by gaining third party qualifications by attending training courses.
Although this never seems to stop anyone installing fire alarms......sparkies....
you may think that you are very capable and you maybe are but most who think this do it all wrong .
doubt very much if they are even aware of 5839-1.
unless you have been fully trained to 5839-1 then you are not fully capable
Guest Cerberus NI
...what he said!
Well thanks for the comment chaps.
I did think you would need to have some sort of qualification.
I do have a clue have been servicing fire alarms and installing fire alarms for 1 of the biggest security companys now in the uk.
Because of a merge of these 2 major companys i have questioned my role and have decided to go self employed. I am just trying to get more info about wot work i will be able to do straight away.
I am fully qualified for intruder and cctv and have a fair few BTECs in these fields but nuthin in fire. Looks like i may have to take another trip to my traing provider haha :unsure:
Guest anguscanplay
good luck, I hope it works out for you - where abouts in the UK are you?
Guest Cerberus NI
Click Here for the FIA and their modular courses on 5839 Pt 1. If you have been doing some fire then it should be a case of putting what you know into context with what the standards say.
Yer thanks for that i will look into what courses maybe available to certify to install and commision fire alarms.
I will be covering all North Wales area and north west area. Thank you ;)
