Jason123 Posted March 24, 2008 Posted March 24, 2008 Hi all, I have just recommissioned my alarm, I replaced zone 2 contact with PIR and powered up as necessary, all lit as expected. I did the walk test and PIR is sensing OK as are all other zones. What Im curious about is when omitting zones. Zone 2 doesnt light up??? All the others do. Zone 2 lights ok during the walk test, any ideas, regards, Jason
antinode Posted March 24, 2008 Posted March 24, 2008 Hi all, I have just recommissioned my alarm, I replaced zone 2 contact with PIR and powered up as necessary, all lit as expected. I did the walk test and PIR is sensing OK as are all other zones.What Im curious about is when omitting zones. Zone 2 doesnt light up??? All the others do. Zone 2 lights ok during the walk test, any ideas, regards, Jason Was the contact on your main entry/exit door by any chance? If so, and the zone is programmed as entry/exit, you are'nt normally able to omit E/E zones. Trade Member
Jason123 Posted March 24, 2008 Author Posted March 24, 2008 Was the contact on your main entry/exit door by any chance? If so, and the zone is programmed as entry/exit, you are'nt normally able to omit E/E zones. No. Zone 2 is the kitchen, I didnt want contacts on the patio doors, so I replaced with PIR. Since you mention it, zone 1 lights with the others when omit is pressed, I have successfully omitted all zones before, I could understand not being allowed to omit entry exit, but its not an option Ive programmed in.
Jason123 Posted April 9, 2008 Author Posted April 9, 2008 Some additional info, when the alarm is set zone 2 doesnt activate the alarm?? This afternoon, I opened up the box and put the wires onto zone 6, programmed out zone 2 and programmed in zone 6. Walk test gave six beeps. Set alarm, tried to omit, zone 6 doesnt light Let alarm set, and tried to activate PIR, nothing happens, does anyone have any idea? I checked continuity, and there is nothing between tamper cct and pir cct
Specialist Posted April 9, 2008 Posted April 9, 2008 Some additional info, when the alarm is set zone 2 doesnt activate the alarm?? This afternoon, I opened up the box and put the wires onto zone 6, programmed out zone 2 and programmed in zone 6. Walk test gave six beeps.Set alarm, tried to omit, zone 6 doesnt light Let alarm set, and tried to activate PIR, nothing happens, does anyone have any idea? I checked continuity, and there is nothing between tamper cct and pir cct Hi Jason: When you did the walk test, how did you know that the PIR was activating? Was it by any chance due to the light on the PIR lighting or did someone stand by the panel for you?. Going on your description of the fault it may be a good idea to check that you have not got the Tamper and Zone wiring reversed, in the PIR. Regards: Andy@Amman Security. Customers Love us, Intruders Hate us.
Guest anguscanplay Posted April 9, 2008 Posted April 9, 2008 Hi Jason: When you did the walk test, how did you know that the PIR was activating? Was it by any chance due to the light on the PIR lighting or did someone stand by the panel for you?. Going on your description of the fault it may be a good idea to check that you have not got the Tamper and Zone wiring reversed, in the PIR.Regards: Andy@Amman Security. er - wouldnt he know about that if he had? O/P when you say you "recommisioned " the system, what EXACTLY did you do?
Jason123 Posted April 9, 2008 Author Posted April 9, 2008 Hi there, I have used green and yellow on the tamper cct, blue and red on the alarm cct, and black and white on the supply. I disconnected everything and meggered every wire, no shorts at all. I ran the brand new cable in a new suspended ceiling direct from the panel to the pir. Its really starting to annoy me now. anyway, Jason
Specialist Posted April 9, 2008 Posted April 9, 2008 er - wouldnt he know about that if he had?O/P when you say you "recommisioned " the system, what EXACTLY did you do? It wouldnt be the first time I have come across this happening and the person not having realised what they had done. Customers Love us, Intruders Hate us.
Guest anguscanplay Posted April 9, 2008 Posted April 9, 2008 O/P when you say you "recommisioned " the system, what EXACTLY did you do?
Jason123 Posted April 9, 2008 Author Posted April 9, 2008 Sorry forgot to mention, I can hear the panel in the porch, from the kitchen, during the walk test.
