Working Out What Battery To Use
I know there is a formula out there for working out the sze of battery to use or for working out how long a battery will last without main's if anyone knows it can you enlighten me please.
NSI GOLD
BASED IN KENT
INTRUDER,ACCESS CONTROL,CCTV,FIRE
Guest anguscanplay
er ?
battery capacity divide by current drawn divide by hours,
but to comply with EN you do the sums backwards to get max current available ie a 7amp battery will limit the panel current to 575ma
The minimum capacity of valve regulated lead acid batteries should be calculated in accordance with the following formula:
Cmin = 1.25 (T1 I1 + D I2/2)
where
Cmin = minimum capacity of the battery when new at the 20 h discharge rate and at 20
