A Few Questions Re; Voltage Drop Etc.
daubs8
ok lets try again (without everybody) picking on mi
24v you need at each dome.
how many amps do these domes need each and how many domes are at the end of the 700 metre run ?
4 domes in total, 1 at 300m, 1 at 450m, 1 at 600m and the last one at 700m. I require 24v AC and maximum 1.5 Amp at each. Thanks
i normally cable the 24v in 2 core flex flat twin. 0.75mm csa
07475071344
On the information given that would give a volt drop of 27.9v on a 24v camera :rolleyes:
Mmmm so - 3.9v. Anyone ever got a dome working with this?? :)
sorry forgot to say thats up to about 50-60 metres not 300 :P :P :P :P
07475071344
That will be 18.42v at the head then over 60m
