daubs8 Posted March 28, 2008 Posted March 28, 2008 I am having to install redwall detectors at distances of between 3 and 700 metres! I am running other wires through galvanised conduit and was hoping to run 8 core for the detectors! Do I have any other options other than supplying 240v closer to the towers I will be fixing the detectors to??
daubs8 Posted March 31, 2008 Author Posted March 31, 2008 I am having to install redwall detectors at distances of between 3 and 700 metres! I am running other wires through galvanised conduit and was hoping to run 8 core for the detectors! Do I have any other options other than supplying 240v closer to the towers I will be fixing the detectors to?? Convinced client to allow me to use Genesis wireless so sorted now.
satsuma01 Posted March 31, 2008 Posted March 31, 2008 Convinced client to allow me to use Genesis wireless so sorted now. couldnt you just run the power through a twin flat flex rated at .75mm "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
Alarm Protection Posted March 31, 2008 Posted March 31, 2008 couldnt you just run the power through a twin flat flex rated at .75mm QFA! !
daubs8 Posted April 1, 2008 Author Posted April 1, 2008 QFA! QFA?? Dunno what that means! It wasn't so much the power, it's the signal. Anyhow, I have used Genesis over 750 successfully in the past. This job is just a vehicle storage compound so I have line of sight etc. so no probs now. Thanks. p.s. Spoke with optex who recommend no more than 100m for wired redwall detectors.
satsuma01 Posted April 1, 2008 Posted April 1, 2008 QFA?? Quoted for agreement.!! "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
