newbitstuck Posted March 30, 2008 Posted March 30, 2008 Hi all and anyone. Have just 1st commissioned the veritas r8. In PROG mode, walk test: led 1 lit and repeated single beep. (all other zones beep and light correctly when activated) i have powered down and up to restore factory settings to no avail. i have now removed all zones and put all zone links back (all other wiring to bell, rkp, tamper etc in place) - same 1 beep repeating on led 1 on rkp. any ideas or is this new panel goosed. .? Off on holiday tonight and would like to have it working if poss.. for looking
antinode Posted March 30, 2008 Posted March 30, 2008 Sounds like there is a fault with the panel if it is showing Zone 1 as open with the link fitted. What you could do as a temporary fix is move the old Zone 1 detector over to, say, Zone 8 for the time being, and just omit Zone 1 when you need to set the system. Trade Member
newbitstuck Posted March 30, 2008 Author Posted March 30, 2008 [What you could do as a temporary fix is move the old Zone 1 detector over to, say, Zone 8 for the time being, and just omit Zone 1 when you need to set the system. Hi.. in between stuff here.. thanks for reply. I dont think its a zone 1 fault tho - cos i put all the links back in?
black knight Posted March 30, 2008 Posted March 30, 2008 is it def Z1 and not the tamper LED? try doing a factory reset - instructions are in Eng manual. Also make sure Batttery is ok P THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
antinode Posted March 30, 2008 Posted March 30, 2008 [What you could do as a temporary fix is move the old Zone 1 detector over to, say, Zone 8 for the time being, and just omit Zone 1 when you need to set the system.Hi.. in between stuff here.. thanks for reply. I dont think its a zone 1 fault tho - cos i put all the links back in? If the panel is showing the Zone 1 LED with a link in Zone 1, then there is a panel fault. As I said, swapping the detector on Zone 1 (which there is probably nothing wrong with) to another zone for the time being will work as a temporary fix, you will just have to go through the omitting proceadure to disable zone 1. Tamper fault would be 9 beeps, if I remember correctly. Trade Member
newbitstuck Posted March 30, 2008 Author Posted March 30, 2008 If the panel is showing the Zone 1 LED with a link in Zone 1, then there is a panel fault. As I said, swapping the detector on Zone 1 (which there is probably nothing wrong with) to another zone for the time being will work as a temporary fix, you will just have to go through the omitting proceadure to disable zone 1.Tamper fault would be 9 beeps, if I remember correctly. Battery and mains ok. all fuses ok. done factory reset. all zones linked (ie there are no active zones now). Still z1 led and single repeat beep at rkp.. .. ok. i will try this now: put all zones back in but link out z1 and omit it. Put 'z1' to new zone. i do think it is panel fault, so not sure if it'll let me actually set the alarm...?? back a.s.a.p!
dunt Posted March 30, 2008 Posted March 30, 2008 try omitting zone 1 in programming when in eng mode hit in 50 take out 1 and prog & see how that goes.
newbitstuck Posted March 30, 2008 Author Posted March 30, 2008 H y'all..! right sorted. Yippee. thanks to you all for bothering.. omitted z1 and relocated etc. re-programmed zones etc, tested etc and we're up and running. do you think this existing problem with the panel will affect things in the future. shall i replace when i get back.. ta .
antinode Posted March 30, 2008 Posted March 30, 2008 H y'all..! right sorted. Yippee. thanks to you all for bothering.. omitted z1 and relocated etc. re-programmed zones etc, tested etc and we're up and running. do you think this existing problem with the panel will affect things in the future. shall i replace when i get back.. ta . Did you buy new, from a shop? If so, take it back and explain the fault. They will give you a new one. Trade Member
alterEGO Posted March 30, 2008 Posted March 30, 2008 H y'all..! right sorted. Yippee. thanks to you all for bothering.. omitted z1 and relocated etc. re-programmed zones etc, tested etc and we're up and running. do you think this existing problem with the panel will affect things in the future. shall i replace when i get back.. ta . check for a dry joint on the back of zone one terminals.
