Eneo Dvr
Alarm Co
trying to connect 16 channel eneo dvr to internet havin trouble setting up with everythin please help
There are quite a few ports to forward on the eneo, i set a few up, you have to forward all the ports on the router (thats if the sites using one)
What you getting stuck on?
Dean
Watchdog Security (Manchester)
hi dean
basicaly the instructions for the eneo dvr are useless when it comes to setting up remote dvr?
i got ip address do i use the one on the back of router? can i / do i need to change it?
subnet mask ? where do i get this from ? rear of router? wot is it?
port 80? the eneo is set to 50000? do i need to change to 00080?
and how do i change fire wall settings for the ports on my router
questions make the mind grow wiser
hi dean
No the subnet will probably be 255.255.255.0 if its a smaller network, you need to port forward that port 50000 to the internal ip of the Eneo in the Router pages. what make is the router? Dont forget you will need to enter the gateway (router ip) in the eneo also and the eno needs to be in the same subnet ip range as the routers scope (ie if router is 192,168.1.1 then your eno will need to be 192.168.1.X where x isnt used on the network)
thanks for reply
just been reading into it and now trying to figure out port forwarding
