ln1234 Posted April 4, 2008 Posted April 4, 2008 Hi Guys, Are there any good recomendations for a video door entry system for residential properties? Am looking for something that has a reasonably small camera on the 'doorbell' and has 2 way audio. Was looking at the following from tlc-direct, but these have been there for a couple of years (at least) so not sure if there is anything better on the market. http://www.tlc-direct.co.uk/Main_Index/CCT...eo_1/index.html Thanks
iSTORM Posted April 4, 2008 Posted April 4, 2008 Hi there, i use this kit below, but i'm not sure if they will deal with none trade, you may have to find a company to supply to you in your area. Bell Systems My Name is Iain iStorm Security Solutions Visit My Website
C.S TEK. Posted April 4, 2008 Posted April 4, 2008 was there not a system callled visebell?? Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006
totalsec Posted April 4, 2008 Posted April 4, 2008 Hi Guys,Are there any good recomendations for a video door entry system for residential properties? Am looking for something that has a reasonably small camera on the 'doorbell' and has 2 way audio. Was looking at the following from tlc-direct, but these have been there for a couple of years (at least) so not sure if there is anything better on the market. http://www.tlc-direct.co.uk/Main_Index/CCT...eo_1/index.html Thanks Try this http://shop.one-stopsecurityshop.ihoststud...roductid=VEKIT2 decent kit cheap and easy to install. Do you Know a good local locksmith in your area if so please let me know as i might have some work for them. Thanks.
justin Posted April 6, 2008 Posted April 6, 2008 Hi Guys,Are there any good recomendations for a video door entry system for residential properties? Am looking for something that has a reasonably small camera on the 'doorbell' and has 2 way audio. Was looking at the following from tlc-direct, but these have been there for a couple of years (at least) so not sure if there is anything better on the market. http://www.tlc-direct.co.uk/Main_Index/CCT...eo_1/index.html Thanks Videx is generally the most popular choice and is decent gear but can be quite expensive. If your on a budget then SRS do quite a good range.
