aleksandras1234 Posted April 7, 2008 Posted April 7, 2008 Hello, we're designing complex security system (fire, intrusion, cctv, access control) for a small factory. All systems will be supervised via PC monitors whith installed suitable soft. Fire alarm system will be addressable, 8 loops; intrusion alarm - about 16 partitions and 128 zones. So, our customer want to supervise both (addressable fire alarm and intrusion alarm) on 1 monitor (all fire and intrusion detectors and other devices should be on the same plan). Is there possible? Which security manufacturer has such soft?
Guest G.J.M Posted April 7, 2008 Posted April 7, 2008 Hello, we're designing complex security system(fire, intrusion, cctv, access control) for a small factory. All systems will be supervised via PC monitors whith installed suitable soft. Fire alarm system will be addressable, 8 loops; intrusion alarm - about 16 partitions and 128 zones. So, our customer want to supervise both (addressable fire alarm and intrusion alarm) on 1 monitor (all fire and intrusion detectors and other devices should be on the same plan). Is there possible? Which security manufacturer has such soft? don't know about combined but what you need for fire and intruder is available indepandantly with graphics software etc. why do you need such big systems for a small factory?
aleksandras1234 Posted April 7, 2008 Author Posted April 7, 2008 Actually, it's quite large object. It's not matter object's size. Combining addressable fire + security - it's a wish of our customer. First of all, I offered him "GE Security", but when he found that both systems: (ATS 4000 and FP2000) have different software, he said: "It's not suitable for us. Look for a systems which integrates both addressable fire and intrusion alarm system on one graphic plan".
Guest G.J.M Posted April 7, 2008 Posted April 7, 2008 i would recommend giving GEC a miss for Fire anyway. The FP200 range is Aritech they have no UK tech support and have really went downhill imo
Guest G.J.M Posted April 7, 2008 Posted April 7, 2008 http://www.notifier.com/products/pages/onyxworks.htm
aleksandras1234 Posted April 7, 2008 Author Posted April 7, 2008 The object is not in UK, It's in one of Baltic state.
arfur mo Posted April 7, 2008 Posted April 7, 2008 having the ability to monitor and control combined security systems is not unheard of, what would worry me is that you want it all on one monitor. this could leave the operator open to multi-sytem calls if say a fire damaged an intruder cable, signals from both could arrive at the same time, fir would be the 1st priority, so the CCTV will not be watching the guy knicking the gear having caused the fire to get in. many people suddenly have a rush of blood, before thinking it through decide they are definately going for an Apollo type space ship control room, so a simple word of sage advice here - K.I.S.S. (Keep It Separate Stupid ) regs alan If you think education is difficult, try being stupid!!!!
aleksandras1234 Posted April 7, 2008 Author Posted April 7, 2008 In presentation about "ONYXworks" I found that it communicate whith "Ademco Vista" control panels - those are not suitable for me (too little partitions). Does "ONYXworks" cooperate with "Galaxy G3" or other Honeywell panels, which has 16 partitions?
secboy Posted April 7, 2008 Posted April 7, 2008 Hello, we're designing complex security system(fire, intrusion, cctv, access control) for a small factory. All systems will be supervised via PC monitors whith installed suitable soft. Fire alarm system will be addressable, 8 loops; intrusion alarm - about 16 partitions and 128 zones. So, our customer want to supervise both (addressable fire alarm and intrusion alarm) on 1 monitor (all fire and intrusion detectors and other devices should be on the same plan). Is there possible? Which security manufacturer has such soft? Take a look at Honeywell "PROWATCH" that should do what you want!!! Paul
sparky999 Posted April 7, 2008 Posted April 7, 2008 Hello, we're designing complex security system(fire, intrusion, cctv, access control) for a small factory. All systems will be supervised via PC monitors whith installed suitable soft. Fire alarm system will be addressable, 8 loops; intrusion alarm - about 16 partitions and 128 zones. So, our customer want to supervise both (addressable fire alarm and intrusion alarm) on 1 monitor (all fire and intrusion detectors and other devices should be on the same plan). Is there possible? Which security manufacturer has such soft? Hi been reading the comments Check out this site they may be able solve your problem. Pete DRAX Peter Robinson Freelance M:07889038650
