Scantronic 4600
keith454
Hi All.
we have had a scantronic 4600 in the house for 16 years.
it hasn't been used for the last 10 due to the kids and dog always setting it off.
now the kids are older and the dog was sadly put to sleep a week ago i want to start using the alarm again.
i've changed all the batteries and done a walk test and all seems fine. however, i've just found out we have a chime on two of the sensors that i want to disable.
is there a way of doing this or would an engineer be needed.
thanks in anticipation to a reply.
thanks for the reply.
unfortunately i have tried what you said but the chime remains on.
any other ideas or should i just scrap the system and get a new one.
4600 User Commands From the Keypad
Full Set > User code + 2
Unset > User code
Part Set > User code + 1
Omit Zones > User code + 2 + OMIT + zone number. (Repeat
OMIT + zone number for all zones to be omitted.)
Keypad PA > 1 + 3
Silence Bells > User code
Reset > User code
Change User Code > 6 + Enter + existing code + new code + Enter
Walk Test > 3 + Enter + User code + activate detectors + Enter to end test
On older units: User code + 3 + Enter + activate detectors + Enter to end test
Chime On/Off > 4 + Enter + User code
Will sound silly I know but if the above is not solving your problem, have you got any smoke detectors that need new batteries?
Guest anguscanplay
edited
lol, i think i may well have. thanks anyway.
I'll have a look through the threads and see what systems are top of peeps lists.
