Ademco Accord
newsatten
Hi,
Can someone help please?
I have a bells only Ademco Accord intruder alarm system. i want to delete the all codes and have only one master code. I believe I have successfully changed the master code by entering the following on the control panel (codes are examples)
1234 8 1 5678 followed by two beeps
I have then tried to delete the other user codes by entering the new master code
5678 8 2 followed by two beeps
5678 8 3 etc upto user code 9.
The problem is that when I test the codes are gone they have not been deleted. How can I permanently remove all the user codes and enure the master code i want is the only code in use?
The other problem is the standby battery no longer works, can someone recommend where I can buy a new one please?
All help much appreciated.
Kind regards
Newsatten
Hi try using the master code eg 5678,8,user number you wish to delete,then*.
Sounds to me that your possibly trying to prog all users to the same number-that won't work
Regards Richard. :rolleyes:
Hi Richard,
I just tried that but it did not work, I entered the following on the control panel
5678 (example master code) 8 2 *
It beeped twice but when I have gone back and entered the user code I have tired to delete for example 9999 the 9999 code is still valid.
Any thoughts?
Many thanks
Is this of any help, page 10?
Accord_xpC_User_Instructions.pdf
ps If this is not the right Accord panel, let us know the correct one, I'm sure the correct manual will then appear.
Hi,
Page 10 worked a treat thank you so much!!! My alarm is not actually the XPC model but it would appear the settings are the same.
I really appreciate your help with this matter.
Do you by chance know where I can purchase a replacement standby battery for the accord?
Thanks again
Newsatten
Hi, most electrical wholesalers will do them-open the lid-tamper will go off-put your code in to shut it up,check capacity of battery ie 1.2 ah,replace lid,reset panel, get same battery.
maplins do them as well but they're twice as expensive!!.
Richard
