Veritas 8 Power Query
Fornari
Hi folks,
I've just registered here in the hope someone might be able to help with me a query regarding my Veritas 8 alarm.
This morning, the fuse for my lights at home blew.
I turned off the power for everything at the mains while I removed the blown fuse.
When I switched the power back on at the mains everything worked okay - plug sockets, oven etc - except for my alarm. The power light on the alarm panel is flashing on and off and I was unable to set the alarm on Full as I left the house.
The battery in the alarm is a couple of years old.
I'm unsure what to do next - any suggestions gratefully received!
Thanks in advance.
Hi ,
The green flashing light indicates a power supply problem , so either the mains to the panel is missing , or more likely the battery has run down and the panel is indicating this as a problem.You may find that the light will stop flashing soon , but it may be wise to get it checked out and possibly a new battery fitted.
Regards.
The alarm was last serviced about two years ago.
Thanks for your suggestions with this, it really is much appreciated. I will try and pick up a new battery later today and see if that solves the problem.
Fastcar - if it was a problem with the mains to the panel, would this be solved by fitting a new fuse in my fusebox or would I need to address something within the panel itself?
There should be a fused spur close to the alarm panel with a 3amp fuse , there is also a fuse within the panel at the incoming connector block.
Be careful around hazardous voltages ..if in doubt , get an engineer to check it out.
Thats definately a knackered battery. Had it many times.
Thanks for all the suggestions - I've rewired the fuse in the mains box and fitted a new battery inside the panel and we now have power back.
Since restoring power, though, the Tamper light is permanently lit - can anyone suggest how to remedy this?
Had a similar problem, when I investigated found the panel mains block was damaged, bloody takeovers lol
