barrieeld Posted April 10, 2008 Share Posted April 10, 2008 Im looking to instal a CCTV system for a cafe and have around 4-5k to spend. Im looking for good coverage externally with 7 camers being required to protect the building and outbuildings with 4 cameras need internally (1 above the till and the others covering the floor space). What should i be going for, whats the best cameras to use? I want a rack system which will be installed upstairs in an office (prob 18U) with a 16 channel dvr unit required. Can anyone point me to what i should be going for and where to shop for it to get the best price. Many thanks Barrie Link to comment https://www.thesecurityinstaller.co.uk/community/topic/22875-need-a-cctv-system-for-a-restraunt/ Share on other sites More sharing options...
Chorlton Posted April 10, 2008 Share Posted April 10, 2008 are you the resturant owner or the camera installer or both? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/22875-need-a-cctv-system-for-a-restraunt/#findComment-194751 Share on other sites More sharing options...
barrieeld Posted April 11, 2008 Author Share Posted April 11, 2008 Hi there folks any response as to what cemeras (internal and external) and equipment i should be looking to by. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/22875-need-a-cctv-system-for-a-restraunt/#findComment-194781 Share on other sites More sharing options...
Chorlton Posted April 11, 2008 Share Posted April 11, 2008 are you the resturant owner or the camera installer or both? Hi there folks any response as to what cemeras (internal and external) and equipment i should be looking to by. you go 1st Link to comment https://www.thesecurityinstaller.co.uk/community/topic/22875-need-a-cctv-system-for-a-restraunt/#findComment-194792 Share on other sites More sharing options...
Alarm Protection Posted April 11, 2008 Share Posted April 11, 2008 11 camera system(7 outdoors) 16 way DVR Lockable cabinet Do you want to view externally? Cabling and connectors I would advise that you get a local CCTV installer to do the quote/job for you. You might not even need all these cameras as from experience when the customer is saying "i need a camera here and there" but then heres cameras also look at theres camera so no point fitting 2! With the amount of cameras you want then i would go for a qoute first. ! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/22875-need-a-cctv-system-for-a-restraunt/#findComment-194822 Share on other sites More sharing options...
