Can Anyone Help Me Get This Camera Working?
This is David ******************************************************
Hope I can help you.
You see body camera have two kind of mounting way: C/CS, you can check which one you are.
Maybe you need the ring, Cause thedistance from lens to CCD is different.
C:17.526mm
CS:12.5mm
So if you put the lens suit the CS to C, you should ad one ring to it.
Hope it can help you.
Actually to be accurate David, if you want to use a CS mount lens on a C mount camera .... you can't :no:
On the other hand, if you want to fit a C mount lens on a CS mount camera, then simply screwing a 5mm spacer ring onto the lens, will move it away from the imager enough to be able to bring the image into focus.
