ee01003 Posted April 16, 2008 Share Posted April 16, 2008 hi, i am a newbie in the cctv systems. i have some problems in calculating the storage needs in a cctv system. i know that the factors that i have to considered when calculating storage needs are: -number of cameras -number of hours per day, that the camera will be recording -how long the data must be stored - frame rate , compression, image quality and complexity for the bellow exemple (per example) : if i have 1 camera whit: resolution= 640 * 480 frames per second=25 period of storage= 8 hours compression = MJPEG (50) i know that i have to use this formula (FOR 1 CAMERA): required storage space=image size* frames per second * period of request my principal question is how i can calculating the image size? and how resolution and compression influences the image size? and for the case that i use the m4peg? how can i know the storage requeried ? how can i know the bandwidth requeried ? can anybody help me? best regards Link to comment https://www.thesecurityinstaller.co.uk/community/topic/22924-calculate-the-storage-needs/ Share on other sites More sharing options...
breff Posted April 16, 2008 Share Posted April 16, 2008 I would allow 15-20gb per camera for 8 hours@25fps although I estimate about 19gb. attached is a storage chart from dedicated micros, they say 25k equates to better than 400 tv lines. storagechart.pdf The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/22924-calculate-the-storage-needs/#findComment-195144 Share on other sites More sharing options...
ee01003 Posted April 17, 2008 Author Share Posted April 17, 2008 thanks for your help... i have seen your attached, but i don Link to comment https://www.thesecurityinstaller.co.uk/community/topic/22924-calculate-the-storage-needs/#findComment-195191 Share on other sites More sharing options...
