Clock Not Working
nintenbo
hi all
Got an old and cheap Maplin 4 ch DVR, ( actually its not as bad as what you may think) anyway the in built clock doesnot work. I can set the time and date but when i exit to live pictures and the clock dont move, even when play back. i thought it may be the internal battery but replaced it but no joy even shorted the two jumpers next to it but nothing.
any ideas??
I have come across one or two DVRs that had a similar problem, in these cases a motherboard change was the final course of action. Not to say thats whats wrong with yours you could try the following:
- A Software reset (should be an option to go to factory default in the menus)
- Remove the battery and do not replace for a while (10 mins usually does it) this may also reset the machine.
- Format the hard drives.
Thats all I can think of at the moment.
Good Luck.
hi all
any ideas??
my suggesetion would be try and do a hard reset on the unit, and if tht doesnt work it maay be cheaper to just upgrade to a better unit.
cheers
07475071344
ive tryed most of that but if im honest i prob didnt leave it long enough for the battery being left out so will try it for longer this time also i will try a different hard drive, as this one was second had.
thabks for replys and i will post im findings
thanks
thanks
:no: i meant hard reset through the menu of the dvr may do the trick.
cheers
07475071344
ive tryed all the aboveof . i may just have to leave it at that, had maybe look for a not so cheap replacement,
thanks for all your replys tho
cheers guys
