daubs8 Posted April 19, 2008 Posted April 19, 2008 Hi. I'm being really thick so can somebody help please? I am running 240v single phase armoured cable 400m then using a 1 amp 24v psu, I am then continuing for a further 100m then another 24v 1 amp psu, then 2 more 100m runs each with a 1 amp 24v psu. So in total the run is 700m with 4 amps. Can anybody tell me what size cable to use? I was thinking 2.5mm but hoping for 1.5mm. I appreciate I may be way out but i've got
camerabloke Posted April 19, 2008 Posted April 19, 2008 what you trying to power Eucam Security Systems 0845 4630 746 www.eucam.co.uk
camerabloke Posted April 19, 2008 Posted April 19, 2008 how are you powering the amps? Eucam Security Systems 0845 4630 746 www.eucam.co.uk
daubs8 Posted April 19, 2008 Author Posted April 19, 2008 how are you powering the amps? I am running 240v armoured to a fuse spure then attaching a 24v psu at each tower
camerabloke Posted April 19, 2008 Posted April 19, 2008 i am possibly thinking 6-10mm minimum Eucam Security Systems 0845 4630 746 www.eucam.co.uk
daubs8 Posted April 19, 2008 Author Posted April 19, 2008 mmm not too bad if thats the case, dont suppose anyone has a rough price if it is 6mm? I have
billythebellbox Posted April 19, 2008 Posted April 19, 2008 don't have my design stuff here but 10mm is 2 amps @ 230v for 700m De Do Do Do, De Da Da Da. De Do Do Do, De Da Da Da
spider Posted April 19, 2008 Posted April 19, 2008 Hi. I'm being really thick so can somebody help please? I am running 240v single phase armoured cable 400m then using a 1 amp 24v psu, I am then continuing for a further 100m then another 24v 1 amp psu, then 2 more 100m runs each with a 1 amp 24v psu. So in total the run is 700m with 4 amps. Can anybody tell me what size cable to use? I was thinking 2.5mm but hoping for 1.5mm. I appreciate I may be way out but i've got
camerabloke Posted April 19, 2008 Posted April 19, 2008 might be worth going 25mm then? gona cost a fortune Eucam Security Systems 0845 4630 746 www.eucam.co.uk
