g1hsg Posted April 24, 2008 Posted April 24, 2008 Hi all. I've just been out to a 9800+ system which required reprogramming following some internal building works. I need to point out that I've only ever worked on one 9800 before and generally not much time on Scantronic, tend to stick to Texecom. All was going fine until I tried to program one zone as walkthrough on full set and final exit on two part sets. This doesnt seem to be possible from reading the installation notes. I think that Scantronic were still manufacturing these panels until late 90's or early 000's - surely this must be possible to do ? The other less palatable alternative is that I can't read manuals !! Thanks Neil
antinode Posted April 24, 2008 Posted April 24, 2008 You can only program which zones are active in which part sets on a 98. You can't chose alternate zone types for each part set. Trade Member
Guest anguscanplay Posted April 24, 2008 Posted April 24, 2008 You can only program which zones are active in which part sets on a 98. You can't chose alternate zone types for each part set. yes you could on an old 9800 - select the zone type as " access.. " then select the access zones as either imediate or entry / exit in part set, if it stops raining I`ll go to the garage and get the actual numbers
breff Posted April 24, 2008 Posted April 24, 2008 option 61, area b entry route, 0=entry route,1=start entry timer The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
black knight Posted April 24, 2008 Posted April 24, 2008 option 61, area b entry route, 0=entry route,1=start entry timer Part Set (Commands 60 - 63, 70 - 73) Commands 60 to 63 program the Part Set functions for area B, commands 70 to 73 carry out the same operations for area C. Each command controls the following: Final Exit Response (Command 60/70) Commands 60/70 control how the system will treat Final Exit zones during a Part Set. When the command option is set to 0 any Final Exit zones included in the Part Set areas will continue to act as Final Exit zones during Part Set B or C. When the option is set to 1 any Final Exit zones included in the Part Set areas will act as Normal Alarm zones while the system is Part Set. Entry Route Response (Command 61/71) Commands 61/71 control how the system treats Entry Route zones during Part Set B or C. When the option is set to 0 all Entry Route zones included in the Part Set areas will continue to act as Entry Routes during Part Set. When the option is set to 1 any Entry Route zones included in the Part Set areas will act as Final Exit zones while the system is Part Set. Exit Mode (Command 62/72) Commands 62/72 specify the exit modes for each Part Set area. Option 0 makes the Part Set Area use the same exit mode as Full Set Option 1 makes the Part Set Area Instant Set (no exit buzzer) Option 2 makes the Part Set Area Silent Set. The Exit time is the same as that programmed for Full Set. Alarm Response (Command 63/73) Commands 63/73 specify the alarm response for each Part Set area. Option 0: Keypad bleepers only THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
magpye Posted April 24, 2008 Posted April 24, 2008 Can someone please tell me when the Forum Rules were changed? Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
