dogtag Posted April 25, 2008 Posted April 25, 2008 Anyone have experience of leaving Dome PTZ on 24/7 tour? Any reliability problems.? Any manufactures say this should not be done? all
Alarm Protection Posted April 25, 2008 Posted April 25, 2008 Not set up many like this but 4 x 360 vision domes work fine on tour 24/7 2 x Dynamic domes fine and 1 COP dome worked for about 2 weeks and burnt out! and was replaced with a higher end dome and is working fine. I would advise that you use a decent dome for the job. !
camullins Posted April 25, 2008 Posted April 25, 2008 Not set up many like this but4 x 360 vision domes work fine on tour 24/7 2 x Dynamic domes fine and 1 COP dome worked for about 2 weeks and burnt out! and was replaced with a higher end dome and is working fine. I would advise that you use a decent dome for the job. I have installed many VCL/Honeywell Orbiter Golds Never had any problems yet. But like Scottish Engineer says. High end domes
NickD Posted May 8, 2008 Posted May 8, 2008 Unofficially, Pelco says that dome (ie, mechanical) life is effectively halved on their Spectra I/II/III's. Unsure about spectra IV's or mini. Tried once getting this in writing from them but to no avail.
djandysp Posted May 8, 2008 Posted May 8, 2008 Unofficially, Pelco says that dome (ie, mechanical) life is effectively halved on their Spectra I/II/III's. Unsure about spectra IV's or mini. Tried once getting this in writing from them but to no avail. Weve got 2 Spectra II or III's on tour, they have been for the last 4 years and the only problem we find is when theres a power cut one of em (mounted on a tree of all places) it sometimes doesnt self test properly and stays out of focus. As for the tree bit all I'll say is I didnt do it and I once nearly dropped it as its a bugger to get to
satsuma01 Posted May 8, 2008 Posted May 8, 2008 Weve got 2 Spectra II or III's on tour, they have been for the last 4 years and the only problem we find is when theres a power cut one of em (mounted on a tree of all places) it sometimes doesnt self test properly and stays out of focus. As for the tree bit all I'll say is I didnt do it and I once nearly dropped it as its a bugger to get to "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
djandysp Posted May 8, 2008 Posted May 8, 2008 As I said I didnt do it if I had my way the tree would be down lol
