markash Posted April 25, 2008 Posted April 25, 2008 I installed the Premier 24 panel in Jan and have had no problems with the system apart from one niggling thing which I just can't work out. I do a Part 3 set every evening when going to bed, the only omitted zone is the landing PIR. To set the alarm I usually just press 3 then PART then make my way up the stairs. Most of the time this works fine but occasionally when I get within range of the landing PIR it acts as if it
kka Posted April 26, 2008 Posted April 26, 2008 the 3 then part option needs to be programmed in engineering, or else code - part - 3 - yes sorry cannot be of any more help Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
