Atex Certified Detectors
never heard of explosion proof detectors would you also need explosion proof cable
Mark Terry
A.M.I. Security
Covering the Thames Valley
Tel. 01189 775173 24hours
mark.terry@amisecurity.co.uk
Hello I'm looking for ATEX certified "Ex" (explosion-proof)
intrusion alarm products (detectors, magnetic contacts etc.).
Who produces?
Thank you.
I'm guessing you mean the type of stuff used in the Petrochem industry?
I believe that Norbain used to supply a range of camera housings which were explosion proof so they may be able to help you, might also be worth looking at the RS Components Website, they do quite a bit of stuff for hazardous environments.
Sentrol make detectors for explosive atmospheres, as had been commented, the device and cable should be supplied through IS barriers to limit the discharge of energy etc etc , check out the DSERA regs as well
