Najim5 Posted May 1, 2008 Posted May 1, 2008 Hello, I have unmonitored Accord XPC and need to reprogram it due to chewed wire by a mouse. I appreciate if anyone can email me the Engineering Manual for that control panel. Thank you in advance. Naji
antinode Posted May 1, 2008 Posted May 1, 2008 Hello,I have unmonitored Accord XPC and nehttp://www.thesecurityinstaller.co.uk/community/style_images/ip.boardpr/folder_editor_images/rte-textcolor.gif Text Colored to reprogram it due to chewed wire by a mouse. I appreciate if anyone can email me the Engineering Manual for that control panel. Thank you in advance. Naji Unfortunately, as you will understand, it is against forum rules to give out engineering information to public members of this site due to the potential security risk and also due to copyright issues imposed on us. Your system likely does not need reprogramming. It should be a case of re-connecting the wires, replacing any blown fuse in the main panel and resetting with your user code. Be careful if you go inside the main panel as there are dangerous voltages present. Trade Member
Najim5 Posted May 1, 2008 Author Posted May 1, 2008 Unfortunately, as you will understand, it is against forum rules to give out engineering information to public members of this site due to the potential security risk and also due to copyright issues imposed on us. Your system likely does not need reprogramming. It should be a case of re-connecting the wires, replacing any blown fuse in the main panel and resetting with your user code.Be careful if you go inside the main panel as there are dangerous voltages present. Thank you very much antinode for your reply. NajiMuslih@yahoo.co.uk
