BigDave Posted May 4, 2008 Share Posted May 4, 2008 Hi, First of all, hello, this is my first post. We are having new french doors and I need to remove the Aritech Shock sensor from the existing patio doors. I've noticed it has four wires going in. Is there anything I can do to these wires to permanently remove the sensor? This is to get round the problem of re-installing the sensor on the new doors (we never use the alarm but might want to activate it in the future). EDIT: FYI - not sure if this helps, but the wires are black, red, yellow and blue. Hope you can help, Thanks David Link to comment https://www.thesecurityinstaller.co.uk/community/topic/23109-removing-aritech-shock-switch/ Share on other sites More sharing options...
satsuma01 Posted May 4, 2008 Share Posted May 4, 2008 Hi, First of all, hello, this is my first post. We are having new french doors and I need to remove the Aritech Shock sensor from the existing patio doors. I've noticed it has four wires going in. Is there anything I can do to these wires to permanently remove the sensor? This is to get round the problem of re-installing the sensor on the new doors (we never use the alarm but might want to activate it in the future). Hope you can help, Thanks David it probably has a positive and negative supply for power, and an alarm pair which shohld be n/o (normally open. "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/23109-removing-aritech-shock-switch/#findComment-196477 Share on other sites More sharing options...
whistle Posted May 4, 2008 Share Posted May 4, 2008 it probably has a positive and negative supply for power, and an alarm pair which shohld be n/o (normally open. I think you will find aritech inertias have no aux power to the device. Here we go agian blind leading blind. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/23109-removing-aritech-shock-switch/#findComment-196478 Share on other sites More sharing options...
lawandorder Posted May 4, 2008 Share Posted May 4, 2008 it probably has a positive and negative supply for power, and an alarm pair which shohld be n/o (normally open. That's a new one on me, is it a pressure mat in disguise? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/23109-removing-aritech-shock-switch/#findComment-196500 Share on other sites More sharing options...
Cubit Posted May 4, 2008 Share Posted May 4, 2008 That's a new one on me, is it a pressure mat in disguise? Perhaps a polite way of explaining said answer is he's guessing. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/23109-removing-aritech-shock-switch/#findComment-196501 Share on other sites More sharing options...
lawandorder Posted May 4, 2008 Share Posted May 4, 2008 Hi, First of all, hello, this is my first post. We are having new french doors and I need to remove the Aritech Shock sensor from the existing patio doors. I've noticed it has four wires going in. Is there anything I can do to these wires to permanently remove the sensor? This is to get round the problem of re-installing the sensor on the new doors (we never use the alarm but might want to activate it in the future). EDIT: FYI - not sure if this helps, but the wires are black, red, yellow and blue. Hope you can help, Thanks David Please think about what your telling a member to do and the possible consequences. Unfortunately there is no standard colour code used by alarm companies so it's impossible to tell which ones are which without testing them. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/23109-removing-aritech-shock-switch/#findComment-196502 Share on other sites More sharing options...
billythebellbox Posted May 4, 2008 Share Posted May 4, 2008 Here we go agian blind leading blind. the nature of internet forums, plenty of advice most of it wrong De Do Do Do, De Da Da Da. De Do Do Do, De Da Da Da Link to comment https://www.thesecurityinstaller.co.uk/community/topic/23109-removing-aritech-shock-switch/#findComment-196505 Share on other sites More sharing options...
BigDave Posted May 5, 2008 Author Share Posted May 5, 2008 Please think about what your telling a member to do and the possible consequences.Unfortunately there is no standard colour code used by alarm companies so it's impossible to tell which ones are which without testing them. Thanks. Taking the cover off, the mechanism with what sounds like ball bearings inside has two wires (red and yellow), and the other two (blue and black) are connected to either side of the sensor base. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/23109-removing-aritech-shock-switch/#findComment-196523 Share on other sites More sharing options...
satsuma01 Posted May 5, 2008 Share Posted May 5, 2008 That's a new one on me, is it a pressure mat in disguise? i realised how i wrote it and as i was tired and it was fairly late that must be why anyway sorry i meant to say n/c normally closed NOT open "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/23109-removing-aritech-shock-switch/#findComment-196525 Share on other sites More sharing options...
alterEGO Posted May 5, 2008 Share Posted May 5, 2008 it probably has a positive and negative supply for power, and an alarm pair which shohld be n/o (normally open. i was going to mention the which way around they have to go but i can see we have an expert already at hand Link to comment https://www.thesecurityinstaller.co.uk/community/topic/23109-removing-aritech-shock-switch/#findComment-196548 Share on other sites More sharing options...
