Dabsbhatti Posted May 4, 2008 Posted May 4, 2008 Can you spur power for a Galaxy G2 from a 15A ring mains lighting circuit, or does it have to be from a 30 amp mains Ring.
kka Posted May 5, 2008 Posted May 5, 2008 where is angus or arfur when you need them...... i always take the spur from the 30amp socket ring main, (upstair ring if possible) using 2.5mm t/e cable to the 3amp fused connection unit and then 1.5mm to the panel.. sure some one later may be more precise with the 17th edition electrical regs.... beware, even thought its may be you own property, you may well need it certificated to comply with hip regs. hip = home information pack ? danger - 24ovac, cannot be seen, and does kill in the wrong hands. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Guest anguscanplay Posted May 5, 2008 Posted May 5, 2008 Dabsbhatti said: Can you spur power for a Galaxy G2 from a 15A ring mains lighting circuit, YES or does it have to be from a 30 amp mains Ring. DOESN`T "HAVE TO BE..." we`ll let others argue about it not been good practise, we just take power from the nearest point, as long as you comply with the regs and building control etc it isnt really a problem nowadays Angus .
satsuma01 Posted May 5, 2008 Posted May 5, 2008 topalarms said: Better to avoid lighting circuits for alarm systems. i always put it on its on circuit direct from consumer unit! "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
Cubit Posted May 5, 2008 Posted May 5, 2008 satsuma01 said: i always put it on its on circuit direct from consumer unit! Really? And when there is no spare capacity?
satsuma01 Posted May 5, 2008 Posted May 5, 2008 Cubit said: Really?And when there is no spare capacity? ill cross that bridge when and if i come to it. "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
Cubit Posted May 5, 2008 Posted May 5, 2008 satsuma01 said: ill cross that bridge when and if i come to it. Really??
satsuma01 Posted May 5, 2008 Posted May 5, 2008 Cubit said: Really?? "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
