Accessing 'comms Mode' On Dm D4 Via Hyperterminal
zs123
hi,
i know some DM units are +++ or Esc Esc Esc to enter comms mode when attached to DS2 / ECO via serial and Hyperterminal.
can anyone advise how you access comms mode on a dedicated micros D4, tryed the above keystrokes but no luck, any help would be great
cheers
What is it that you are trying to achieve?
no the drive has failed so it wont boot far enough to show the IP im not aware if it even has one set?
i would presume it is on 192.168 but that is just an assumption.
not aware what DM software will auto detect? network viewer doesnt does it? thought you had to input IP?
