Veritas R8
had an electrical failure in the entire barnsley region early this morn, since then the tamper light wont go off , so i cannot set the alarm, out side alarm box continually flashes tamper light
What lights are showing on the remote keypad?
Is the mains light on, if so is it on permanently or flashing?
may have blown a fuse on the board, bell one for instance...it may be worth you while to get someone in to check it out,
when was it last serviced, it may need a new back up battery..
beware mains voltages kills when in contact with humans...always isolate trhe mains feed before opening any alarm box....
Guest anguscanplay
you need a new battery and the system power cycling
Angus
If the sounder is showing it has a tamp fault. I assume one of the leds isnt flashing, then i doubt its a fuse problem else th eother light wouldnt be on. Did you do anything else duri9ng the power failure, ie mess with the external sounder?
Looks to me like you have a sab tamper
Guest anguscanplay
everyone need to go back and read this thread again
mains fail this morning ? tamper light on since ? strobe flashing since ?
panels been powered up with a dead battery and locked out, it cant be reset so it cant stop the strobe flashing - its as simple as that
