Dsc Pc1565 Power Problems
paulh13
Hi guys -- thank god for this forum !
I have a household DSC PC1565 (or similar - Canadian ??) which has been reliable up until now
Has battery backup and was monitored back to base up until 24 months ago
about 10 years old
Have had a lot of alarms going off even when we are inside the house for no reason and the
monitor is supposedly not set and also during the day when we are not at home - so much so that the neighbours complained and we stopped setting the alarm altogether
Called installer who changed/removed tamper switch connection ???
Having doubts about this ? When we reconnect power the system resets and seems ok
for 5-10 minutes then beeps 3 times and power light comes on/flashes - it then beeps 3 times
every 10 minutes or so - very frustrating at 3am in the morning
Have now turned off altogether - could it be the back-up battery that needs replacing
any tips/ideas would be very much appreciated
Regards
Paul from Oz
Sorry if this model/type is not available in the UK
about 10 years old
Regards
Paul from Oz
Yep its a DSC "Classic" panel..
If the panel is 10 years old it will need a new battery, as for the beeps if you have fully powered down the panel then you will need to set the clock again..
There is more details about trouble conditions on page 11-12 of the user manual (can't post a user manual) but if you haven't got one you can do a search on google for "PC1565" you will find one ;)
Hi guys
Have followed recommendations but still having problems ?
Powers up ok - have tried to set time/date but it beeps just before i punch in the 8 of the 08 part of the mmddyy
Anyway did time/date but 12 hours later it beeped 3 times and the power light started flashing ??
Please any ideas would be gratefully accepted ???
  • 2 weeks later...
Hi guys
Did you press star than 2 to view the trouble. is it a wired system or wireless
Hi guys
Dont know this panel but with others you have to power up irst then connect battery or connect battery first then power up???
Maybe it could be the batery fuse that has blown????
Hope this helps
