bigstevex Posted May 12, 2008 Posted May 12, 2008 I want to add a gsm module onto my alarm and be able to interact with my alarm while i'm away by being able to reset it or turn it off if need be, but do i need a com module or do i not? Can't find the relevent info anywhere I've got a speech and text dialler on it at the moment but its just uses the 4 outputs from the premier 48 that can be set for different things, i.e alarm/failed to arm/mains failure etc. or If i get the texecom gsm dialler does it have this function already built in?? PLEASE HELP ME, ITS DRIVING ME CRAZY
IanHug Posted May 15, 2008 Posted May 15, 2008 Don't have the GSM module but looking at the instructions for the GSM module: Con1 - This 2.1mm power plug should be plugged into the power socket on the GSM module. Con2 - This RJ45 type connector should be plugged into the RJ45 Headset socket on the GSM module. Con3 - This 7-way Molex type connector should be plugged onto Com 2 on the Premier48/88/168 control panel. Con4 - This 5-way Molex type connector should be plugged onto the AUDIO port on the Premier Com300/2400 communicator (this is only required if you want to use the GSM Module as a backup for the Com300/2400). Connection to Com300/2400 looks optional to me. Manual doesn't say it needs Com300/2400 to function for remote control.
bigstevex Posted May 16, 2008 Author Posted May 16, 2008 Ah, so con3 will be how it talks to the premier48 Super! That'll do fine thanks, Its just annoying that the unit is ~
whibbs Posted May 17, 2008 Posted May 17, 2008 Ah, so con3 will be how it talks to the premier48 Super! That'll do fine thanks, Its just annoying that the unit is ~ Wayne Hibbs
bigstevex Posted May 18, 2008 Author Posted May 18, 2008 Thanks for the help guys Just waiting to be paid now lol.....
