Guest Johnny Posted May 18, 2004 Posted May 18, 2004 I have just (DIY) fitted the above Panel, with PIR's and remote panel. When i switch on following the user guide, I find that the Remote goes straight into tamper Mode. I've checked the wiring and connections but can't see why it won't fire up as it should. Any pointers ? .
FASTCAR Posted May 18, 2004 Posted May 18, 2004 Have you closed all tampers ..panel lid , rkp lid , bell tamper , global tamper.Link out until you find the culprit , then investigate. B)
Guest dale Posted May 18, 2004 Posted May 18, 2004 Check that the tamper spring on the keypad and the control panel are secure. Also might be a good idea to short the tamper circtuit to see if that identifies the problem. It could also be the bell tamper, make sure you have wired the bell up correctly and the tamper switch in the bell is pressed down securely. D
