jimbo2000 Posted May 13, 2008 Posted May 13, 2008 Hi Everyone, Don't know if anyone can help me with this one. I have a optima compact
Rulland Posted May 13, 2008 Posted May 13, 2008 Hi, Sounds like you needs a new battery this should keep the alarm powered-but it may make a few noises to let you know the mains has gone off. Once that has been done you should be able to turn the mains on/off with no probs-you might just have to enter your code to silence/reset the system. Richard.
stevie Posted May 15, 2008 Posted May 15, 2008 your battery is knackered mate. you need a 12volt 2.1ah or 2.3ah battery. either one will do. then its just a case of opening the panel up (2 srews on the front) and replace the battery. when you open the box the alarm will go off inside only. just enter you code to stop the noise, you will be left with the power/tamper LED`s on. then change the battery. once you have put it all back together press reset. now you should be able to do your lights. hope this help , steve....
