Veritas 8 In Tamper
methomp
Recently I removed a large wardrobe down our stairs and accidently hit the movement sensor on the stairway with the wardrobe. This resulted in the tamper light on the control panel illuminating red. I can not set the alarm now. The 'Unset' & 'Power' LEDs are both illuminated green.
Does anyone have a solution to this problem. Thanks.
Mark
Guest RJBsec
Mark
Refit the stairway sensor covr properly to rectify the tamper fault, assuming the detector hasn't been damaged.
If in doubt call a local engineer.
