Small Cctv Housing For Baxall Required
kuchars22
Hello,
For a residential house, I'm looking for an external housing that will take a standard-sized Baxall "box" camera. I used to have a Dennard 2010 enclosure but it's too big and want something more compact so that it just houses the camera. Is there such a product on the market?
Thanks
as to my thread , im resorting to making my own but would like something only as big as a box camera and not as standout-ish as some of them out there
good luck tho will let you know if i come across any
Hello,
Thanks
The size of the housing is determined by the camera/lens combination with approx 30-50mm extra for coax connections and power.
At a low level the 2010 may seem unsightly at on the second story acts as a good deterrent. If you need a small housing I'd consider a decent day/night ip rated camera with inbuilt leds or a vandal dome.
Kind regards
Stuart Onley
SAMS Consultancy
Independent Security Consultants
email:enquiries@samsconsultancy.co.uk
website:www.samsconsultancy.co.uk
I already have a vista all in one which is great, but wanted to see if there was anything even smaller!
